How to disassembly the CrowPi
Here are the steps to disassembly the CrowPi:
1.Remove the screws on the base board and pry the board forcefully. Click here to watch the video.
2.Remove the screws that hold the flat cable
3.Use the torx screwdriver to remove the screws that hold the acrylic plate, then pry the plate forcefully.(Be careful not to damage the camera)
4.Remove the screws that hold the flat cable
5.Remove the copper pillar that holds the sreen
6.Unplug the HDMI and USB (touch) cables
7.Remove the crowatil cable on the back of the board
Once you've done, you've completely dismantled the CrowPi.
