UART0 issue again
hi there,
I own a 5" and a 7" BASIC Elecrow Display.
They both can communicate with a "EBYTE LoRa Module"
but not with any ESP32 (AZ-Delivery / HELTEC etc) or even them thelves!
No matter with or without USB connected (separate power)
and / or with or without a level converter,
the signal does not reach ground level in theses cases.
Is there any thing I miss?
Kind Regards, hm_heli
«1
  • Dear Customer/Sender,
    Best regards,
  • hi there,
    here's the requested info: (at least I have available)
    ordered directly at Elecrow
    order #252486 SKU DIS07050H-001 and DIS08070H-001
    order #244725 SKU DIS02050A-2-3 (not tested using UART0!)
    order #222459 SKU DIS08070H
    order #249437 SKU DIKS07050H- 001
    Best regards, hm_heli
  • Dear Customer ,
    Please provide the code and photos of the device wiring for us to analyze .
    Thanks!
    Warm regads,
  • hi there,
    Please provide the code and photos of the device wiring for us to analyze <<<
    really???
    anyway, I'm trying to send 6 fotos showing every thing but it does not allow me to post.
  • hi there,
    here are the photos..
    meanwhile I tested with an Arduino ESP32-Nano...surprise: it works!
    To me it looks like that it depends on the used USB/UART chip being used on the different ESP's and the displays.
    1. my displays do NOT talk to each other
    2. my displays do NOT talk to the larger ESP32
    3. my displays do talk to the ESP32-Nano
    4. the skope pictures show a good and a bad sinal
    5. I tested with and without a level converter
    6. the test program can't be simpler..
    Any thoughts, hints...?
    Regards
  • @hm_heli said:
    hi there,
    Regards
    Best regards,
  • Dear hm_heli,
    Under normal circumstances, communication is possible; there are no hardware limitations between the screens.
    Please refer to our example program:
    Thanks!
    Best regards,
  • hi there,
    my English does not suffice to express my disappointment concerning this answer!
    I understand that 90% of the questions you receive are beginner like.
    But if someone provides photosgraphs of a corrupted signal taken from an oscilloscope when two Elecrow displays are connected via RX/TX I expect something better!
    Regards
    We have received your email, and our technical support team is reviewing the details. Please allow us some time to look into the matter. We will get back to you as soon as possible with an update.
    Best regards,
  • Dear hm_heli,
    Sorry to keep you waiting.
    We apologize, we've also tested this and it doesn't work. Other products from the Advanced series work fine. The product you're using is from the Basic series. This series might be experiencing this issue due to an automatic download update. We tested it on devices with lower hardware versions of your device, and it worked, but it didn't work on devices with hardware versions 2.0 and above.
    Here is the hardware version.
    Very sorry for the inconvenience caused.
    Thanks!
    Best regards,
