Strange Error when compiling Lesson 4 (Drawing board) 7 inch V3.0
Hi
I copied the provided PCA9557 file into the Libraries folder.
Now i get this error (7" v3.0):-
.......\libraries\LovyanGFX\src\lgfx\v1\platforms\esp32s3\Bus_RGB.cpp: In function 'void lgfx::v1::_gpio_pin_sig(uint32_t, uint32_t)':
d:\OneDrive\ESP32\libraries\LovyanGFX\src\lgfx\v1\platforms\esp32s3\Bus_RGB.cpp:98:5: error: 'gpio_hal_iomux_func_sel' was not declared in this scope; did you mean 'gpio_hal_func_sel'?
98 | gpio_hal_iomux_func_sel(GPIO_PIN_MUX_REG[pin], PIN_FUNC_GPIO);
| gpio_hal_func_sel
exit status 1
Compilation error: exit status 1
Please tell what I need to do.
I tried various things (replacing the gfx_conf.h with the 'new' version, installing GT911 libraries etc..) but each time I get a new error about some file not found ..
I'm stuck. Please help.
Please, can someone send me a working example (just one of the demo codes) working on the 7" HMI ? Thank you!
Is anyone from Elecrow support reading this forum?
Dear roycejp,
Sorry for the late reply.
May I ask if you are using the library files we provided? If not, please try these instead: :
https://www.elecrow.com/download/product/CrowPanel/ESP32-HMI/7.0-DIS08070H/Arduino_Tutorial/libraries.zip
also, here thers is the method about how to use them :. you can refer to if you need .
https://www.elecrow.com/wiki/ESP32_Display_7.0-inch_HMI_Arduino_Tutorial.html#install-libraries
Thanks !
Warm regards,
I Created a fresh arduino workspace and copied all the libraries there.
Then I copied the 'crowpanel-esp32-7.0-3.0-touch" folder from the new course material (lesson 4) to here.
Ram & Partition scheme is setup as instructed.
When I compile I get this error:
In file included from d:/OneDrive/ESP32-ELECROW/libraries/lvgl/src/core/lv_obj.h:140,
\OneDrive\ESP32-ELECROW\7.0 v3.0 touch new code\4\crowpanel-esp32-7.0-3.0-touch\crowpanel-esp32-7.0-3.0-touch.ino:2:
\OneDrive\ESP32-ELECROW\7.0 v3.0 touch new code\4\crowpanel-esp32-7.0-3.0-touch\crowpanel-esp32-7.0-3.0-touch.ino: In function 'void setup()':
\OneDrive\ESP32-ELECROW\7.0 v3.0 touch new code\4\crowpanel-esp32-7.0-3.0-touch\crowpanel-esp32-7.0-3.0-touch.ino:220:3: error: 'ledcSetup' was not declared in this scope
\OneDrive\ESP32-ELECROW\7.0 v3.0 touch new code\4\crowpanel-esp32-7.0-3.0-touch\crowpanel-esp32-7.0-3.0-touch.ino:221:3: error: 'ledcAttachPin' was not declared in this scope; did you mean 'ledcAttach'?
\OneDrive\ESP32-ELECROW\libraries\SPI
\OneDrive\ESP32-ELECROW\libraries\Wire
from d:/OneDrive/ESP32-ELECROW/libraries/lvgl/lvgl.h:35,
from d:\OneDrive\ESP32-ELECROW\libraries\lvgl\src/lvgl.h:17,
from
d:/OneDrive/ESP32-ELECROW/libraries/lvgl/src/core/lv_obj_style.h: In function 'void lv_obj_remove_style_all(_lv_obj_t*)':
d:/OneDrive/ESP32-ELECROW/libraries/lvgl/src/core/lv_obj_style.h:94:48: warning: bitwise operation between different enumeration types '' and '' is deprecated [-Wdeprecated-enum-enum-conversion]
94 | lv_obj_remove_style(obj, NULL, LV_PART_ANY | LV_STATE_ANY);
220 | ledcSetup(1, 300, 8);
221 | ledcAttachPin(TFT_BL, 1);
| ledcAttach
Multiple libraries were found for "SPI.h"
Used:
Not used: C:\Users\Dell\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.4\libraries\SPI
Multiple libraries were found for "Wire.h"
Used:
Not used: C:\Users\Dell\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.4\libraries\Wire
exit status 1
Compilation error: 'ledcSetup' was not declared in this scope
Please help.
I finally managed to compile the 'draw.ino' project without errors, but the screen is blank (dark).
Do I need to change any settings ?
What does this error mean?
I have rechecked the board, Ram & partition settings...all OK.
error:
Invalid FQBN: getting build properties for board esp32:esp32:esp32s3: invalid option 'ZigbeeMode'
Compilation error: Invalid FQBN: getting build properties for board esp32:esp32:esp32s3: invalid option 'ZigbeeMode'
Dear roycejp,
Best regards,
Hi,
SKU DIS08070H
Purchase Site:
ROBU **dot **in.
I am not allowed tp post any links I seems.
How to send you a link?
I get this error with the touch program:
Library Wire has been declared precompiled:
Using precompiled library in d:\OneDrive\ESP32-ELECROW\libraries\Wire\src\esp32s3
Library lvgl has been declared precompiled:
Precompiled library in "d:\OneDrive\ESP32-ELECROW\libraries\lvgl\src\esp32s3" not found...
But there is 1 file 'liblvgl-3.a' in the esp32s3 folder.
The libraries tab also says 'lvgl 8.3.3 installed' .
d:\OneDrive\ESP32-Elecrow\is my sketches folder.
I have copied all your supplied libraries into the libraries folder here, as you instructed.
