First failure of 5" ESP32 panel - DIS07050H
We are doing some testing using DIS07050H panels and one has just popped with smoke out of U1 (3.3V buck IC). We are running them by supplying 3.3V from the host and this worked great for months until this one failed.
We had assumed that U1 was off because it had no VCC, either from USB socket or the battery. I am therefore unsure why it would fail. Additionally, removing U1 removed the short but the panel will not boot. It now draws 240mA rather than the previous 500 - 600mA. Clearly, U1 is not the only item to fail.
I have no problem ordering a replacement panel but I am trying to understand why it failed. Is there a problem with an external 3.3V supply? Do we need to modify the boards? Any thoughts...
Thank you.
