Can your monitor support Fire TV?
Our monitor does not have a built-in Fire TV system, so it cannot directly support Fire TV; but if the monitor has an HDMI interface and speakers (or speaker interface), and can be powered by USB or socket (many of our monitors meet these conditions), it should be able to be used with Fire TV Stick to support Fire TV (we have not tested it, but we speculate that it should be possible based on the device specifications. You can buy it and try it). In addition, it is recommended that you can also consult the seller of Fire TV Stick.
Thanks for the detailed explanation! That makes sense if the monitor has HDMI and audio output, using a Fire TV Stick should work fine in theory. I’ll give it a try and check with the Fire TV Stick seller as well to be sure. Appreciate the recommendation!
