Dual Channel H-Bridge Motor Shield - Elecrow
https://www.elecrow.com/wiki/index.php?title=Dual_Channel_H-Bridge_Motor_ShieldThe Dual Channel H-Bridge Motor Shield is composed of 2 discrete MOSFET H-bridge, designed to drive two DC motor with max current 8A. It is made up of 8 N-channel MOSFET IRF3205S and 4 pcs of half bridge motor controller IR2104, to build 2 H-bridge. With this shield and the Arduino board, users can control and drive motors with a max current 8A@ 22V.
this is the link included how to wire the board and how to code。
And this H-Bridge Motor Shield board Fully meet your needs。
I connected as wiki says. But no output happening.
What does then wiki instruction mean by...... Motor Shield Output Enable, Should be set to "1" while working
How do I set this?
I put 5v at the EN pin and at the 5v pin. Still nothing
You don’t need to connect pin 6 to 5v, the program is already set to output, which means that the motor has voltage output.
