Adding power switch without removing GPIO ribbon
13»
  • The dtoverlay statement must NOT contain any space(s).
    E.g. dtoverlay=gpio-shutdown,gpio_pin=33
  • That makes sense, what doesn't make sense is in the picture I provided I had dtoverlay=shutdown and still is now working and messing with the I2C
  • edited June 2021
    Not quite understand the current problem you are having, let’s be sure
    • With dtoverlay=gpio-shutdown
    Pressing the momentary switch (wired between Pin 5 and 6) does not initiate a shutdown process but just stops the I2C momentarily.
    If you have another device using the I2C, it would be an expected behavior. You need to specify a different GPIO pin to initiate the shutdown.
    • With dtoverlay=gpio-shutdown,gpio_pin=33
    Pressing the momentary switch (wired to GPIO33 and GND) does not initiate a shutdown process.
    You might be mixing up bewteen GPIO pins and Physical/Board pins. And only GPIO0 to GPIO27 are lead out to the 40-pin connector. So, GPIO33 is not easily accessible. If you’re meant to connect a momentary switch to the Physical/Board pin 33 (GPIO13), then you should specify it as
    dtoverlay=gpio-shutdown,gpio_pin=13
    Hints: You can type pinout in a terminal window to display the 40-pin GPIO header's pinout description.
