CrowPanel ESP32 E-Paper 4.2 crash
I use VisualCode and PlatformIO for programming.
The example code "Openweather" for this display is already compiled and loaded, but the Panel flickers only, no picture.
In the serial monitor see:
Connecting
Connected to WiFi network with IP Address: 192.168.0.91
Timer set to 10 seconds (timerDelay variable), it will take 10 seconds before publishing the first reading.
HTTP Response code: 200
{"coord":{"lon":13.6691,"lat":50.8962}
.................... another
String sea_level: 1021
String wind_speed: 2.24
String city_js: "Dippoldiswalde"
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x8 (TG1WDT_SYS_RST),boot:0x2b (SPI_FAST_FLASH_BOOT)
Saved PC:0x42017693
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce3808,len:0x4bc
load:0x403c9700,len:0xbd8
load:0x403cc700,len:0x2a0c
entry 0x403c98d0
My platformio.ini:
[env:esp32-s3-devkitm-1]
platform = espressif32
;board = freenove_esp32_s3_wroom
board = esp32-s3-devkitm-1
framework = arduino
lib_deps =
    ;bblanchon/ArduinoJson@^7.3.1
    arduino-libraries/Arduino_JSON@^0.2.0
board_build.partitions = partitions_default.csv
  • Hi, gerryvel,
    Since The wiki does not write coding support for PlatformIO, Is it normal when developing with Arduino?
  • edited June 16
    Yes, it's the same with Arduino. The code crash by use the first position "memset" in the void UI_weather_forecast.
    // Display city information
    memset(buffer, 0, sizeof(buffer));
    snprintf(buffer, sizeof(buffer), "%s ", city_js); // Format city information as a string
    EPD_ShowString(301, 51, buffer, 16, BLACK); // Display city name
    Serial.println("Display city information");
