RaspberryPi 5 is broken
SoMy raspberry pi five along with Crow pi It's just broken For startersI cannot turn on the crow/raspberry Pi If the Gray HDMI Wire is plugged in Stuck on a login screen with a mainly white Background And a square in the middle that has a drop down box that can have pi or other And in under Pi I found that the password is supposed to be raspberry But whenever I put that in and click log in the screen goes black and then I just get back to the original screen of white Background. Has anybody had this problem before or does anybody at least know how to fix it
  • 1.Could you confirm what model of crowpi you have? Is it a crowpi?
    2.Is the operating system used the pre-installed Raspberry Pi OS, or did you burn your own?
    3.Have you tried the the defaule password is '1' OR 'raspberry'.
  • Turtl22 - were you able to log in? We are having the same problem and Tech Support hasn't responded. We have the
    ELECROW for Raspberry Pi 5 8GB Kit, with Pi 5 8GB Single Board Computer kit. This is very disappointing and frustrating for my daughter. It was all working fine and then this Log In screen popped up and now she can't do anything!
