What if the device is locked?
GrowCube will be locked when the blockage occurs or the water tank is empty or the sensor is abnormal for more than 3 times. After troubleshooting or adding water, press the unlock button to restore normal operation of the device.
A: Lock the machine due to lack of water
B: Lock the machine due to blockage of waterpump
C: The water outlet is locked due to abnormality in the sensor operation
*If you hold down the button for 3 seconds, the network will be reconfigured.
